Hi All,
I have fx2lp device, when usb plug in Industrial PC and turn on IPC.
the problem will appear as below after IPC is turned on
it is install Windows Embedded Standard 7 SP1 in IPC.
Have any suggestion about this issue?
BR,
Darren
Hi Darren,
- Can you please let me know what is IPC?
- When this issue is seen i.e. while plugging the device or installing the driver?
- Please let us know which interface type you want to configure.
Also, kindly refer to this KBA: https://community.infineon.com/t5/Knowledge-Base-Articles/Drivers-for-EZ-USB-FX1-FX2LP-and-FX3-KBA94...
------------------------------------------------UPDATE--------------------------------------------------
Please download Fx3 SDK from given Path and install.
install and bind driver from below path after SDK installation.
C:\Program Files (x86)\Cypress\EZ-USB FX3 SDK\1.3\driver
------------------------------------------------END----------------------------------------------------------
Hi Darren,
