i develope a firmware for dvb dongle using an fx2 board.
On a linux PC:
when i connect to PC USB and firmware is downloaded, strange things happen.
on the linux PC terminal i get strange character input at random every once in a while.
Also screen resolution changes once in a while (due to strange key input).
The firmware is not functioning as it should.
On a linux LAPTOP:
plugin the dongle into my laptop, after firmware load, kernel panic.
On a raspberry pi:
it works.
This is so strange.
the firmware is processing a lot of "vendor-commands" through EP0. ?!
i am out of ideas....
- USB-noise
OK, found it.
The linux DVB driver assumes an IR-remote receiver inside dvb-tuner device and creates an input device which acts as a keyboard-input (for some reason). So IR-codes arrive into your terminal window.
+++ DVB Tuner, ir-receiver inside dvb-usb not working, it sends spurious keypresses:
solution:
-> create file /etc/modprobe.d/dvb-usb.conf, containing: options dvb-usb disable_rc_polling=1
then on probe, driver does not load ir support.
>> Is the failure on a Linux laptop happening every time or intermittently?
>> Did you check on another host?
>> Can you share the USB logs?
yeah this is mysterious 😉
i guess it is related to my firmware, or ? vid/pid combination: its: 04b4:2104, which is DVBworld 2104 HD device,
but mine is custom hardware, same tuner.
So it maybe that linux, when recoqnizing that vid/pid trys to do something, it shouldnt.
as described above, i tryd it on 3 linux machines, only the raspberry worked fine.
just wonder if anyone has ever experienced these strange "noise" coming rom USB going to keyboard.
will check for USBMON to elaborate further.
OK, found it.
solution:
