USB low-full-high speed peripherals Forum Discussions
A simple function use CY7C63413C, all IO pins just output used to control LED , no input ,no Interrupt.
How to develop the firmware code and the driver code , is there a easy sample code?
ShopithamR_26
25 replies posted 10 replies posted 5 replies posted
 We do not really have a simple example projects to share with you . We have only Keyboard , mouse example project .
Also this part is a very old part . So if you are developing a new produce I recommend you take a look at our EnCoRe II family .
http://www.cypress.com/?id=182
This is a M8C based programmable Low Speed peripheral .
Sobi
Thanks for you information, I will see it . I want to a make a product has a 22 IO ports control switchs.
