10:22 AM
Jun 17, 2009
10:22 AM
Hi guys.
We are developing a usb project with Cy7c68013A-100. We have heavy input traffic and light output traffic. So we dicided to use ep2 as input endpoint and ep8 as output.
But we can't get output data from the fifo pins (FD0 - FD15). FIFOADDR is set to "11". FLAG is signaling like data is going through.
Then we turn things upside down and set ep2 as output endpoint and ep8 as input. And the data appears on the fifo pins, so everything works well.
Does it mean that we can't use ep8 as output endpoint, or we missed something significant?
01:23 PM
Jun 17, 2009
01:23 PM
In page 32 of the trm the 12 possible endpoint configurations is displayed. Are you following this?
04:22 AM
Jun 18, 2009
04:22 AM
Yes. We have used the 11th conifguration (ep2 1024 x 3, ep8 512 x 2), when ep8 was output. And the first configuration (ep2 512 x 2, ep8 512 x 2), when ep2 was output.
01:22 PM
Jun 18, 2009
01:22 PM
I'll see if i can test what you are describing... i remember ep8 working fine...
04:37 AM
Jun 19, 2009
04:37 AM
Here is TD_Init function:
CPUCS = ((CPUCS & ~bmCLKSPD) | bmCLKSPD1); SYNCDELAY; // set the CPU clock to 48MHz
SYNCDELAY;
IFCONFIG = 0x03; SYNCDELAY;
// 0 0 0 0 0 0 1 1
// | | | | | | slave fifo interface
// | | | | | port e no gstate
// | | | | slave fifo's operate synchrously
// | | | IFCLK is not inverted
// | | IFCLK in tri-state
// | internal clockis 48Mhz (not used)
// external clock source on IFCLK
REVCTL = 0x03; SYNCDELAY;SYNCDELAY;//Cypress highly recommends setting both bits to '1'.s
EP2CFG = 0xEB; SYNCDELAY;
// 1 1 1 0 1 0 1 1
// | | | | | | triple
// | | | | | reserved
// | | | | 1024
// | | bulk
// | in
// valid
EP8CFG = 0xA2; SYNCDELAY;
// 1 0 1 0 0 0 1 0
// | | | | | | double
// | | | | 512
// | | bulk
// | out
// valid
EP4CFG = 0; SYNCDELAY;
EP6CFG = 0; SYNCDELAY;
EP1OUTCFG = bmBIT5; SYNCDELAY; //Invalid, bulk
EP1INCFG = bmBIT5; SYNCDELAY; //Invalid, bulk
//Nak all and reset the endpoints
FIFORESET = 0x80; SYNCDELAY;
FIFORESET = 0x02; SYNCDELAY;
FIFORESET = 0x08; SYNCDELAY;
FIFORESET = 0x00; SYNCDELAY; //Restore normal operation
OUTPKTEND = 0x88;SYNCDELAY;
EP2FIFOCFG = 0x0D; SYNCDELAY;
// 0 0 0 0 1 1 0 1
// | | | | | 16bit
// | | | | z-len send allowed
// | | | autoIN (applies only to IN endpoints)
// | | no autoOUT (applies only to OUT endpoints)
// | OEP (applies only to OUT endpoints)
// INFM (applies only to IN endpoints)
EP8FIFOCFG = 0x11; SYNCDELAY;
// 0 0 0 1 0 0 0 1
// | | | | | 16bit
// | | | | z-len send not allowed
// | | | no autoIN (applies only to IN endpoints)
// | | autoOUT (applies only to OUT endpoints)
EP4FIFOCFG = 0; SYNCDELAY;
EP6FIFOCFG = 0; SYNCDELAY;
EP2AUTOINLENH = 0x04; SYNCDELAY; //1024
EP2AUTOINLENL = 0x00; SYNCDELAY;
// since the defaults are double buffered we must write dummy byte counts twice
SYNCDELAY;
EP8BCL = 0x80; // arm EP8OUT by writing byte count w/skip.
SYNCDELAY;
EP8BCL = 0x80;
SYNCDELAY;
EP0BCH = 0;
SYNCDELAY;
EP0BCL = 0;
SYNCDELAY;
FIFOPINPOLAR = 0x00; SYNCDELAY;
// 0 0 0 0 0 0 0 0
// | | | | | | | full flag polarity (active low)
// | | | | | | empty flag polarity (active low)
// | | | | | slwr polarity (active low)
// | | | | slrd polarity (active low)
// | | | sloe polarity (active low)
// | | pktend polarity (active low)
// not used
PINFLAGSAB = 0xBC;SYNCDELAY;
// 1 0 1 1 1 1 0 0
// | | | | flag A indicates ep2 full
// flag B indicates ep8 empty
PORTACFG = 0;SYNCDELAY;
// 0 0 0 0 0 0 0 0
// | | | | | | | PA0 - not int0
// | | | | | | PA1 - not int1
// | | not used
// | SLCS
// PA7 - not FlagD
SYNCDELAY;
// 0 0 0 0 0 0 1 1
// 1 1 1 0 1 0 1 1
// | | | | 1024
// | | bulk
// | in
// valid
// 1 0 1 0 0 0 1 0
// | | | | 512
// | | bulk
// | out
// valid
// 0 0 0 0 1 1 0 1
// | | | | | 16bit
// 0 0 0 1 0 0 0 1
// | | | | | 16bit
SYNCDELAY;
SYNCDELAY;
EP8BCL = 0x80;
SYNCDELAY;
EP0BCH = 0;
SYNCDELAY;
EP0BCL = 0;
SYNCDELAY;
// 0 0 0 0 0 0 0 0
// not used
// 1 0 1 1 1 1 0 0
// 0 0 0 0 0 0 0 0
// | | not used
// | SLCS
// PA7 - not FlagD
