Dear all,
Is there USB to I2C configuration file of CY7C65215?
Also, are we able to update the F/W of CY7C65215 through USB?
Thank you,Shun Furusawa
Hi Furusawa-san,
You can find configuration file in config directory in "CYUSBS236 USB-Serial (Dual Channel) Development Kit"
or "USB-Serial Software Development Kit"
https://www.cypress.com/documentation/software-and-drivers/usb-serial-software-development-kit
USB Serial devices (CY7C65215/213/211) can only configure the region which can visible on Cypress USB-Serial Configuration Utility.
Hirotaka Takayama
Hi Furusawa-san,
Hirotaka Takayama
Hi Furusawa-san,
Using USB Serial Configuration Utility, you can configure (Program the configuration) one device as USB-I2C and and save the configuration into a file using File->Save option.
Muthu
Hi Takayama-san, Muthu-san,
Thank you for your quick answer!
This really helps!
