I have an application to transmit 640x480 image sesnor data over FX2LP USB 2.0 using UVC through FPGA. I tried to find the firmware online, but no result. Then I tried to develop it myself, but it did not work .Can any one provide it ,thanks
Hi Zhang long,
We have already post an example here
USB2.0 Camera Interface Using FX2LP™ and Lattice CrossLink FPGA - KBA222479
Could you please share your firmware that you have tried?
Thanks & Regards
Abhinav
Hi Zhang long,
Hi yyca
Has this firmware been verified working well ? I tried to modify the firmware just based on this, as it didnot work.
Hi zhang long,
I am not the author of this KBA and I have not test the firmware in this KBA.
However, I suppose the author should have test if before pushing them outside.
I suggest you explain what modifications you have done on this example. what information you get in debugging phase.
This could help us to understand the problem you are facing. Just saying "My firmware doesn't work" doesn't make sense.
What firmware did you use? All firmware didn't work for the device so sharing the one you uses will make it easy to look into it and see what the problem is. Showboxtv Gadgets Franklyn Savetube.com
