Hello!
I've got a problem with the cyusb suite for Linux. The installation went ok. Then the manual says that I should use the "cyusb_linux" command to launch the program, but the terminal responds with the following:
cyusb_linux: error while loading shared libraries: libcyusb.so: cannot open shared object file: No such file or directory
But the file exists, and is in /usr/lib/
What should I do to fix this problem?
It's very simple) Just execute command - ldconfig.
This command load libcyusb.so into the emory
Please create a tech support case at www.cypress.com -> Support -> Technical support.
Gayathri
Thanks Ieva. you made my day with LDCONFIG
You all made my day with ldconfig!
