HI everyone, I want to ask off for a problem.Under the android 5.1.1  use cypress 6801 chips, communication mainly use cyusb lib library, but the device communication always cyusb_bulk_transfer function returns -7 when the status value. I want to consult everybody, this is what causes.  thank you !
SrinathS_16
250 solutions authored 100 solutions authored 100 likes received
Hello
- cyusb_bulk_transfer returning -7 indicates that there is a timeout in the data transfer. Please refer to the following link.
libusb.h Source File
- To avoid this, make sure that data is transferred within the specified timeout interval or the timeout value can be increased. Even if the error occurs, data transfer following that transfer could clear the issue.
Srinath S
SrinathS_16
Hello
Srinath S
