I am using CyUSB.dll through a C# application called CyControl, which I modified using the source code Infineon has provided me. I was wondering if it was possible to have the source code of CyUSB.dll as well. My EZ-USB is an old CY7C68014A. Regards!
Kindly download CyUSB3_USB_Suite_Source .zip in the following path: https://www.infineon.com/cms/en/design-support/tools/sdk/usb-controllers-sdk/ez-usb-fx3-software-dev...
This will have the .dll source code.
Mallika
Mallika
