BYTE TEMP;
void FX2LPSerial_Init() // initializes the registers for using Timer2 as baud rate generator for a Baud rate of 38400.
TMOD = (TMOD & 0x0F) | 0x20;
CKCON |= 0x10;
PCON |= 0x80 ;
EICON |= 0x80;
SCON1 = 0x50;
TH1 = 0xB2 ;
ES1 = 1;
TR1 = 1;
EA = 1;
void send_data(BYTE source)
SBUF1 = source;
while(TI1 == 0);
TI1 = 0;
void send_isr() interrupt 7
if(RI1 == 1)
RI1 = 0;
TEMP = SBUF1;
理论上是不应有冲突的,你可以先用这里面的固件测试一下你的板子
