Dear Support and Expert,
We are using cy7c65630 in our product. we didn't have a solid signal integrity design, so we have USB failure once in a while, ( windows 997). is there a diagnosis software that can set the Cy7c65630 in a loopback mode. just like a little device called PMUSB02( from passmark) can test the cable path. I hope I can set the cy7c65630 in an on-chip loopback mode. so I can check the signal path of the whole USB path.
I believe there is one, please give me a link to the dream.
David Sun
Hello David,
Please check USB HSETT at https://www.usb.org/usb2tools for compliance tests in loopback mode.For example, the command LOOP_DEVICE_DESCRIPTOR is used for FS tests in the suite.
Sananya
Hello David,
Sananya
let me have a look, thank you very much.
