 Hi~
  when I used cy68013a in my product ,i modifed the CYUSB3.inf file used my own PID and VID, i used two PIDs to enable the device to execute a script file when start-up, then I try to sign the driver, and the below error occured:
  "MyDeviceLoad.spt in [MyDeviceLoad.file.ext] is missing from [SourceDisksFiles] section in \MyDevice.inf; driver may not sign correctly until this resolved;"
  So i modified MyDevice.inf file as below:
[SourceDiskFiles]
MyDevice.sys = 1
MyDeviceLoad.spt = 1
   Then i signed my driver suceesfully.
    I wonder when I changed the SPT file in my driver, will the sign became invalid?
What do you mean by chanign SPT file?
Have you created a new script file with the same name or changed the name of the SPT file?
Vikas
Vikas
 thanks for your reply. It means I generate another SPT file and use the same name.
smalling
