about the E-PAD connection for CY7C65213-32LTXI
SuSh_1535366
Distributor - Macnica (Japan)
10 solutions authored 10 likes given 10 likes received
Hello.
I would like to know about the E-PAD connection for CY7C65213.
This device has an Exposed PAD.
It is recommended that the EPAD be connected to GND, but I do not want to solder it for the convenience of managing the state of the mounting.
Is it possible to use the EPAD without soldering?
Are there any (negative) effects of not soldering?
Shimamura
MallikaK_22
50 likes received 750 replies posted 250 solutions authored
As you might be aware EPAD is intended for heat sinking. So it should be soldered.
Mallika
MallikaK_22
Mallika
SuSh_1535366
Hi Mallika,
Thank you for your reply.
OK, I will solder EPAD to GND.
Shimamura
