Helo
The customer has already used CY7C68013A on Android OS, but thye are investigating to use it on Windows10. It is necessary to correspond to the customer-specific custom VID and PID set in CY7C68013A with the Win driver prepared for CY7C68013A. Although it is possible to change the driver's Inf file according to the procedure of Cypress application note, the driver signature will be removed when the change is made, so in Win10 it is not possible to install the driver properly.
Therefore, please tell us about the following
Q1) How to get the signature of custom VID and PID driver?
Q2) How to resell this driver by our customer?
Best Regards
Arai
Hello Arai,
If you need to add your custom VID and PID to the existing cyusb3 driver INF (example: in FX3 SDK), you will have to go through the process of Driver Resell where the particular driver package will be shipped to the Customer's Microsoft Dashboard Account and the they can replace the existing INF with their custom INF and submit to Microsoft for signing.
For the procedure of Driver Resell please refer to the CyUSB.pdf in the FX3 SDK (folder path: <fx3 installation directory>\EZ-USB FX3 SDK\1.3\doc\SuiteUSB)
Once you provide us the all custom INFs of the customer for the required OS and architecture that will be used by the for the process of signing the driver, we will validate and verify those INFs.
Once the INFs are validated and verified, we will perform the Driver Resell to the customers Microsoft Dashboard Account where the driver package will be shipped to the provided account name.
The package can be used for the process of certification by replacing the existing INF with the custom one.
Please refer to the CyUSB.pdf and confirm if the customer needs a driver resell.
Yatheesh
Hello Arai,
Yatheesh
Hello Yatheesh san
Thank you for your reply.
Best Regards
Arai
