Hi.
It seems there are two DVKs on the web for the FX2LP .
https://www.cypress.com/file/135296
https://www.cypress.com/file/135301
Which DVK should be installed ?
Regards.
Shigeto
Hi Shigeto,
I understood your concern.
"CY3684 EZ-USB FX2LP DVK Setup (Kit Design Files, Kiel IDE,GPIF Designer, Host applications, Documentation, Examples) " is included an installer (.exe).
Whereas, "CY3684 EZ-USB FX2LP Development Kit (Rev. *B)" is included installers (.exe and .msi).
I guess most of the customer uses .exe installer and install CY3684.
Hirotaka Takayama
Hi Shigeto,
FX2LP DVK (CY3684 EZ-USB FX2LP Development Kit) URL is as follows.
https://www.cypress.com/documentation/development-kitsboards/cy3684-ez-usb-fx2lp-development-kit
Do kindly download "CY3684 EZ-USB FX2LP DVK Setup (Kit Design Files, Kiel IDE,GPIF Designer, Host applications, Documentation, Examples)", then click and start the install process.
Hirotaka Takayama
Hi Hirotaka .
Thank you for your cooperation.
Any way , what is the difference between two kits?
Regards.
Shigeto
Hi Shigeto,
Hirotaka Takayama
