SuSh_1535366
50 questions asked 50 replies posted 50 sign-ins
I am using CYUSB232 RDK to check the operation of CY7C65213-32LTXI.
After connecting the device to the USB, its TXD line is High.
However, once the port is opened / closed by software (ex. TeraTerm Pro), the TXD line becomes indeterminate(Probably Hi-Z state).
Therefore, incorrect data will be sent to the receiving side.
Is there a way to avoid this situation?
Shimamura
Hi Shimamura-san,
Sorry for the delay in my response.
USB bus will enter idle mode if the COM port is closed and USB host can selective suspend the device after idle timeout.
This selective suspend will put the USB-UART device to deep sleep with Tx pin held Hi-Z mode.
Tx pin not in Hi-Z will violate USB specification VBUS current consumption limits.
Hirotaka Takayama
HirotakaT_91
I have not seen this phenomenon.
Could you please explain your settings?
Does it happen even if you use Default Configuration setting?
Hirotaka Takayama
SuSh_1535366
Hello Takayama-san,
Yes, I am using the default setting.
And the serial port configuration is:
baud rate: 19200
data bit: 8
stop bit: 1
parity: none
hand shake: hardware
Shimamura
Hi Shimamura-san,
Hirotaka Takayama
Hello Takayama-san,
Thank you for your reply.
I confirmed that TxD remains High when disabling selective suspend.
Shimamura
