What is the GPIF seuence or chronological order within an decision point / data action point
RoKo_4340761
I am working with  the FX2lp / GPIF and go through the AN57322 (Interfacing SRAM with FX2LP over GPIF)
I wonder about the sequenze "within" a decision point / data action point.
- When will be the databus sampled, either for a read waveform or a write waveform within an IFCLK (rising / falling edge) ?
- When will be the control signals set within an IFCLK ( after/before sampling, rising / falling edge) ?
- When will be the RDY singals be sampled, either asynchrounous (SAS= 0) or synchronous(SAS = 1) within a IFCLK ?
- When will be the logical funtion within a DP finally be executed?
What is the "internal delay" between all the sampling and signal settings?
Getting a better understanding within one IFCLK period, can I assume that IFCLK will be a kind of "trippled" for the sampling, setting CTL signals and following logical functions.
Especially for FIFO waveforms (repeating decision points) this is difficult to understand.
Roman
MallikaK_22
50 likes received 750 replies posted 250 solutions authored
Hello Roman,
I would request you to refer to Chapter 10 , GPIF in the FX2LP TRM attached herewith.
You will be able to understand and find all the above-asked information in it.
Mallika
MallikaK_22
Hello Roman,
Mallika
Hello Mallika,
thanks for your replay.
I`ve gone through the TRM and other application notes, GPIF primer already, but I don`t find explizit answers to my questions. Would you please provide detailed page numbers to look at?
Roman
MallikaK_22
Hello Roman,
Apologies for the delay in my response.
Can you please check Page 129, Decision Point States in the TRM?
