Augustine_Yeh
Level 4
Level 4
5 likes given 50 sign-ins 50 questions asked
Hi Infineon:
Because my product of CY7C65211A is onboard (No USB connector) so that We can't config a .CYUSB file by Cypress tool , Can you help us to make a configuration file for CY7C65211A , The configuration spec as below , Thank !!
configuration set PID/VID=0x04b4/0004, i2c clock=400K
Meghavi
250 replies posted 100 solutions authored 10 likes received
You can try using command line tool for configuration. Please refer this KBA -   https://community.cypress.com/t5/Knowledge-Base-Articles/Command-line-tool-for-configuring-USB-Seria... and let us know if any other queries.
Meghavi
Can you please elaborate the configuration features that you need or the possible configuration that the device is programmed with?
Augustine_Yeh
Level 4
Level 4
Hi
We all follow the default setup except PID/VID and i2c clock as below
configuration set ==> PID/VID=0x04b4/0004, i2c clock=400K
Meghavi
