I encounter problem with comunicating with CY7c60813A-56LFXI chip. Originally it has a winXP driver and working well with my current software. Since I have to used a win7 machine, I download new driver for win7 64 bit. Now my software is not working anymore. is there any change in the CYUSB3.sys that break my software?( the old driver is CyUSB.sys for winxp)
You need to install CyUSB3 driver.Download the kit package from the below link and install. This will also install the CyUSB3 drivers.
http://www.cypress.com/documentation/development-kitsboards/cy3684-ez-usb-fx2lp-development-kit
Please make sure which driver you were using in Xp and which one do you use in Win 7. The latest Cypress driver for FX2LP is CyUSB3. You can download the same from Website (FX2LP DVK or FX3 SDK).
I am attaching a link which will tell you how to migrate to CyUSB3 from CyUSB. http://www.cypress.com/knowledge-base-article/migration-ez-usb-fx2lp-driver-cyusbsys-cyusb3sys-kba92...
The link is showing an 404 error.
what driver you think I should download for CY7c60813A-56LFXI?
thank
tphan
