Dear i have a project to build a kind of usb mass storage product the design if finished and done by an engineer, i am a computer scientist so i don't know anything about.
I already order some proto pcb of my usb key, the design use this controller :
EZ-USB NX2LP-Flex  ( from mouser : CY7C68023-56LTXC) and eight of  S34ML04G1
So if i correctly understood the doc of the nand is programmed the controller act of mass storage device if not it act as "manufactur mode"
So what must be done to have a mass storage device working ?
Thanks in advance
Marc
Hemanth
First like given First question asked 750 replies posted
Hello Marc,
You need to program the NAND using NandMfg Utility.
You can refer to Nand Manufacturing Utility section in the following document:
http://www.cypress.com/mwg-internal/de5fs23hu73ds/progress?id=80TKR6V7a6qbDSX2W8dRDTU2bTSbLTpKAoUIze...
Please let us know for any doubts after going through this section.
hman
Hemanth
Hemanth
Hello Marc,
hman
Hemanth
Hi i am able to program the nand with nandmfg.exe, the size and number of chip is correct. But the usb mass storage device is recognized by windows with a size of 8G instead of 32G ?
Also the usb is only recognized when the nandmfg is runing ?
Thanks in advance.
Marc
