Is the power domain of the two pins "USBDP" and "USBDM" VCCIO?
Vih and Vil are defined with reference to Vccio. Can USBDP/DM follow these specifications?
I would like to know if it is possible to input up to 3.6V, which is the USB2.0 full speed standard. And I also would like to know if Vih and Vil do not change even if 3.3V is applied to VCC.
Tetsuo
Hello Tetsuo-san,
Yes, DP/DM is pulled up to VCC.
No, we cannot manually change the max voltage level of USB DP and USB DM.
As per USB spec (Page 124), “ A USB transceiver is required to withstand a continuous short circuit of D+ and/or D- to VBUS, other data line , GND, or the cable shield at the connector, for a minimum of 24 hrs without degradation. This requirement must be met for a max value of VBUS (5.25V).
So, DP voltage can rise up to 5.25V in the enumeration phase.
May I know why is the customer looking for high voltage levels on DP?
Mallika
Hello Tetsuo-san,
Mallika
Mallika-san,
Thank you for your response.
If DP/DM is pulled up to Vcc, what is the maximum withstand voltage when 3.3V is applied to Vcc?
I just want to know if it is okay to put 3.6V in DP/DM when 3.3V is applied to Vcc.
Tetsuo
Please find my comment below:
Mallika
Mallika-san,
Thank you for answer again.
I will check the specifications.
Tetsuo
