I am facing a huge issue with making the USB work on this device. Unfortunately for some reason the USBUART module is not available for it and I am trying with USBFS.
Even executing the datasheet sample using one of the built-in HID templates causes the software to always hang on USBFS_bGetConfiguration(). I've tried all the possible configurations for USB - HID, no HID, templates, mine. No change whatsoever - the software always hangs on bGetConfiguration().
Speaking about the hardware - nothing specific there, it has been set exactly as from the suggested solution in the datasheet.
Would anyone be able to post here a confirmed working sample for USB on CY7C64343 ?
Thank you all.
PS. To the Cypress' guys:
why there is no USBUART UM for this device?
C'mon guys! Has anyone at all used this USB device to do USB???
It ALWAYS hangs on
while USBFS_bGetConfiguration();
no matter of the USB descriptors, PC OS or whatever else might be.
Please help!
