azot_0
10 replies posted 10 questions asked 25 sign-ins
Any timer effect on data transfer bandwidth?.
Meghavi
250 replies posted 100 solutions authored 10 likes received
If the Timer is halting the transfer then it can affect the transfer rate. It also depends on the hardware and software.
Can you please elaborate more about your application and how the timer is being used?
Best Regards
Meghavi
Best Regards
azot_0
it is a normal timer operation. wake up run till a condition is true then do something and go sleep till next cycle.
MallikaK_22
50 likes received 750 replies posted 250 solutions authored
We have not seen such issues. Can you please let us know if you are observing such an issue at your end? If yes, please share the source code and Lecroy traces.
Mallika
