I'm facing a problem when install USB-Serial SDK to Windows 10 PC.
Below are error message. Even I've installed Microsoft VC++ 2008 Redistributable and try again, but it does not solve the problem.
Please give me advise.
SrikanthD_56
First comment on blog 100 replies posted 50 solutions authored
Where did you download and install the VC++ 2008 from? Please try to download and install the correction version from the below link and see if that resolves the issue.
VC++ 2008
SrikanthD_56
VC++ 2008
Hi Srds,
I've installed VC++ 2008 x64 but it does not worked.
I've reinstalled VC++ 2008 x86 you shared and it solved my problem.
Thank you! Let close this thread
