USB Endpoint configaration
ThM_3776866
Level 4
Level 4
First like received First like given Welcome!
Hi all,
I am working on cypress FX3. I need to pass data from host  to FPGA through cypress. I am stuck with DMA buffer and endpoint creation  concept.
1.How the data in exchange between one end point to another endpoint?
2. is DMA buffer needed for USB data read ? is it possible to read USB data without DMA.
Hemanth
First like given First question asked 750 replies posted
- Based on your description you intend to send the data from USB Endpoint to GPIF interface of FX3.
- To do that you need to create a DMA channel between USB Producer Socket and PIB Consumer Socket.
Please refer to following App Note where it is implemented:
http://www.cypress.com/documentation/application-notes/an65974-designing-ez-usb-fx3-slave-fifo-inter...
Hemanth
Hemanth
