Jun 26, 2022
10:53 PM
Jun 26, 2022
10:53 PM
We are using USB HUB PN# CYUSB3324-88LTXC on the board but in case if we Assemble the PN# CYUSB3328-88LTXC on the same FP (pl. help to re-validate whether its FP compatible), then what other HW or FW changes would be needed to operate the HUB functionalities same as currently used PN# CYUSB3324-88LTXC?
Labels
11:07 PM
Jun 26, 2022
11:07 PM
Yes, you can replace CYUSB3324 with CYUSB3328. There will be no firmware changes required.
The pinout is the same as can be seen in Table 4, Page 23 in the HX3 datasheet.
Mallika
11:07 PM
Jun 26, 2022
11:07 PM
Mallika
