USB low-full-high speed peripherals
qiwec_297866
10 questions asked 5 replies posted 5 questions asked
 Hello!
    I transfer data from 68013A to cpld, using the synchronous salve fifo mode, and the data bus is 16 bit, but I can only read the first word correctly, and the second word is always the same as the first word, please help me!
   the next is my code.
   the 68013A code:
   void TD_Init( void )
{ // Called once at startup
  CPUCS = 0x10;                 // CLKSPD[1:0]=10, for 48MHz operation
    REVCTL = 0x01; // MUST set REVCTL.0 and REVCTL.1 to 1
    SYNCDELAY;
    IFCONFIG = 0x43;        //%Slave FIFO接口模式 采用外部时钟 极性正常 内部时钟输出无效 同步操作
  //%端点2配置,OUT,双缓冲,BULK 批量输出 数据从PC机到68013
  //0xA0 四缓冲 0xA2 双缓冲 0xA3 三缓冲
    SYNCDELAY;
  EP2CFG = 0xA2;     SYNCDELAY;// EP2OUT, bulk, size 512, 2 buffered  命令输出
  EP4CFG = 0x02;     SYNCDELAY;// EP4 not valid
  EP6CFG = 0xe2;     SYNCDELAY;// EP6IN,  bulk, size 512, 2 buffered  数据输入
  EP8CFG = 0x02;     SYNCDELAY;// EP8 not valid
    //在复位端点FIFO 时,为了保证复位正常,防止主控器请求的干扰,先写入 0x80,然后复位端点,最后写入0x00,使能响应请求。
  FIFORESET = 0x80;    SYNCDELAY;          // activate NAK-ALL to avoid race conditions
  FIFORESET = 0x02;    SYNCDELAY;         // reset, FIFO 2
  FIFORESET = 0x04;    SYNCDELAY;         // reset, FIFO 4
  FIFORESET = 0x06;    SYNCDELAY;         // reset, FIFO 6
  FIFORESET = 0x08;    SYNCDELAY;         // reset, FIFO 8
  FIFORESET = 0x00;    SYNCDELAY;         // deactivate NAK-ALL
  //0x11 /16位数据宽度 数据自动提交
    EP2FIFOCFG = 0x01;   SYNCDELAY;
  EP2FIFOCFG = 0x11;   SYNCDELAY;         //AUTOOUT=1, WORDWIDE=1  16位数据宽度
    //16位数据宽度,数据自动提交,可以提交0长度数据封包
  EP6FIFOCFG = 0x0D;   SYNCDELAY;         // AUTOIN=1, ZEROLENIN=1, WORDWIDE=1
//%引脚FLAGC、FLAGB、FLAGC、FLAGB配置
  PINFLAGSAB = 0x00;   SYNCDELAY;         // FLAGB - Indexed 满标志低电平有效
  PINFLAGSCD = 0x00;   SYNCDELAY;         // FLAGC - Indexed 空标志低电平有效
    //%PKEND\SLOE\SLRD\SLWR 高电平有效 空满标志低电平有效 PKTEND高电平有效,不允许短包
  FIFOPINPOLAR = 0x3C; SYNCDELAY;       // FLAGB/A  读写和使能 高有效
    EP6AUTOINLENH = 0x02; SYNCDELAY;
EP6AUTOINLENL = 0x00; SYNCDELAY; //端点6数据包长度512
OEA |= 0x0B;
IOA &= 0xF4;
  The following is the cpld code:
  assign usbifclk = clk;
  always @(negedge clk)
  begin
  if(!rst)
  begin
    present_state <= state_idel;
    count_clk <= 10'd0;
   slrd <= 1'b0;//slrd and sloe is 1 active
   sloe <= 1'b0;
   config_done <= 1'b0;
   done_delay_cnt <= 3'd0;
   user_control_data <= 20'd0;
 end
 else
 begin
 case(present_state)
 state_idel :
 begin
   if((!usbfifo_full)&(usbfifo_empty))
   begin
     present_state <= state_read;
     slrd <= 1'b1;
     sloe <= 1'b1;
   end
   else if((!usbfifo_empty)&(usbfifo_full))
   begin
     slrd <= 1'b0;
     sloe <= 1'b0;
   end
 end
 state_read :
 begin
  if(count_clk <= 10'd511)
  begin
    count_clk <= count_clk + 1'b1;
    if(count_clk == 10'd511)
    begin
      slrd <= 1'b0;
      sloe <= 1'b0;
    end
    else
    begin
      slrd <= 1'b1;
      sloe <= 1'b1;
    end
    if(count_clk == 10'd0)
      user_control_data[15:0] <= fddata;
    else if(count_clk == 10'd1)
      user_control_data[19:16] <= fddata[3:0];
  end
  else if(count_clk == 10'd512)
  begin
    count_clk <= 10'd0;
    config_done <= 1'b1;
    present_state <= state_delay;
  end
 end
 state_delay :
 begin
   if(done_delay_cnt<=3'd6)
     done_delay_cnt <= done_delay_cnt + 1'b1;
   else
   begin
   end
 end
 default :
endcase
end
end
  Now, the problem is that: When I send 1024 bytes through fifo2 to cpld, such as {22 2A 0B 01 01 ... 01}, the cpld can run the code and read over the full 1024 bytes, and user_control_data[15:0] is correct(22 2A), but the received user_control_data[19:16] is always the same as the user_control_data[3:0](22), How can I solve the problem? I checked the sequence diagram, the it seems does right.
