I would like to switch between UART mode (SBC0 Mode 2) and I2C modes (SBC0 Mode 5/6). Is there a command to switch at runtime, or does it require reprogramming the internal flash?
If flash reprogramming is required:
1) How many cycles does the flash endure?
2) Reading and writing of the flash is apparently possible using the READ/WRITE_USER_FLASH requests, (0xE0, 0xE1). Can you provide a config suitable for the CyUSB3Kit-003, changing the SBC0 config from UART mode to I2C mode?
The internal flash generally has two parts:
1. User Flash
2. Config Flash
Config flash is not programmable using the mentioned READ/WRITE requests and for changing the configuration mode from UART to I2C, you need to use the USB-Serial Configuration Utility or the command line utility (Refer to CY7C65211 Serial Communication Mode). The mentioned READ/WRITE requests can only be used to write to the user flash area and not the configuration area.
Sananya
1. User Flash
2. Config Flash
Sananya
Hi Stefan,
The configuration of SCB0/SCB1 could not be switched dynamically at the run time.
You could configure it with USB-serial configuration utility or command line.
One more thing, you will need to reset the board to let the chip enumerate again to make the new configuration valid.
