Hello
Please let me know the details of the data sheet for the specifications of RS485 TXDEN.
<Confirmation details>
Regarding the TXDEN control signal of CY7C65213A-32LTXI, could you please tell me the timing specifications below?
I have listed the above-mentioned target points in the attachment. Please find attached.
Q1) Please tell me the specifications of the Min/Max values for the time from TXDEN Enable to TXD transmission start.
Q2) Please tell me the specifications of the Min/Max values for the time from TXD transmission end to TXDEN Disable.
Q3) Regarding the above values, is it possible to change the time by software?
Best Regards
Hi Noar,
<EDITED>
currently, we don't have this data available in characterization, can you please, let us know what's the purpose of this information.
you can not change the min/max value by software its a fixed firmware part.
Thank You
Varun Narolkar
Hi Noar,
<EDITED>
Thank You
Varun Narolkar
