08:14 PM
Apr 21, 2013
08:14 PM
Hi
I'm not sure about these relation scheme.
When i using slave fifo, fpga receive hsync from sensor.
But i dont know how should i make slwr with hsync.
Can i just use hsync for instance slwr?
How am i make use hsync in slave fifo in FPGA
Could somebody help to me some advice?
12:19 AM
Apr 26, 2013
12:19 AM
Can you please explain if yours is a UVC application?
12:21 AM
Apr 26, 2013
12:21 AM
Usually this is the way line are connected in image sensor application
Frame valid - Slave select
Line Valid - Slave write
Please see if you can use this information.
