Slave Select Out (SSEL_OUT) out timing not in CY7C65211 data sheet - REPEAT
AnMc_4628076
5 replies posted 5 questions asked 5 sign-ins
This question was not quite fully-answered...for my application, I have a mux setup for multiple SPI devices.
Specifically: I need to know the minimum time from SSEL_OUT assertion (going low) to start of the SPI master clock action.
YatheeshD_36
In SPI master mode, the SSEL assertion to SCLK timing is not fixed, It varies with frequency.
At higher Clock frequencies, the time difference between SPI SSEL assertion and SCLK will reduce.
At 2MHz frequency the difference between SS and SCLK it is found to be around 1us, both at the start and end of transfer.
Please let me know the USB-Serial SPI master clock frequency you will be using?
Yatheesh
YatheeshD_36
Yatheesh
