Hello I am using FX2lp and i referred to this article and followed the steps in the article Usage of Serial Ports 0 and 1 on FX2LP, implementi... - Infineon Developer Community
However, I use tera term instead of Hyperterminal but i am not able to see anything on the tera term. I exactly follow the steps but most of the times bulk out and in fails
Hi CSK10,
please try the attached file for testing the virtual com port.
Thank You
Varun Narolkar
Hi CSK10 ,
can you please share the error log or the Wireshark log?
we will check with teraterm and update you ASAP, can you please try with HyperTerminal once .
Thank You
Varun Narolkar
Hi Csk10 ,
which Hardware you are using?
which FX2LP Part you are using ?
Thank you
Varun Narolkar
Hi ,
I use CY3684 fx2lp board and using serial port 0 for this case
