NXTY_Nishinaga
Level 4
Level 4
Distributor - NEXTY (Japan)
10 solutions authored 25 replies posted 5 solutions authored
I want to set the serial communication block configuration of CY7C65223D to Mode3 and use it. How can I change the setting?
I checked the document of Configuration utility( Cypress USB-Serial Configuration Utility 2.0 User Guide), but couldn't find a description about CY7C65223D.
Regards.
Meghavi
250 replies posted 100 solutions authored 10 likes received
The configuration utility present in the USB-Serial SDK will not work for CY7C65223D. Please try the attached Configuration Utility.
Meghavi
NXTY_Nishinaga
Level 4
Level 4
Thank you for your answer.
I’m sorry, please tell me a little more.
What should I do specifically if I use Mode 32 in  CY7C65223D?
(Mode3 means  Table13 and Table14 in  Infineon-CY7C65223D-32LTXI-DataSheet-v01_00-EN.pdf)
Regards.
Please refer to the 2.3.2.3.1 UART Mode section of the USB-Serial Configuration Utility User Guide to change to Mode 3 (8-pin UART).
