Mar 30, 2022
12:01 AM
Mar 30, 2022
12:01 AM
I’m sorry, but please tell me a little more.
What are the specific steps to change the settings to use mode 3 on the CY7C65223D using the Configuration utility?
(Mode3 means Table13 and Table14 in Infineon-CY7C65223D-32LTXI-DataSheet-v01_00-EN.pdf)
Regards.
Labels
Mar 30, 2022
05:59 AM
Mar 30, 2022
05:59 AM
Please refer to the 2.3.2.3.1 UART Mode section of the USB-Serial Configuration Utility User Guide attached to this response to change to Mode 3 (8-pin UART).
Mar 30, 2022
05:59 AM
Mar 30, 2022
05:59 AM
Apr 01, 2022
12:07 AM
Apr 01, 2022
12:07 AM
Thank you very much for your answer.
If I change the setting to Mode3(8-pin UART) using Configuration Utility, will that setting be written to Flash memory?
Apr 04, 2022
08:54 PM
Apr 04, 2022
08:54 PM
I have posted an additional question to the Community, so please check it.
Apr 05, 2022
05:48 AM
Apr 05, 2022
05:48 AM
Yes, the configuration information is stored in Flash memory.
