Hello;
I have a similar condition as was in this thread Solved: regarding fx2lp i2c interface - Infineon Developer Community .
I have a temperature sensor and eeprom using I2C,
In my case the Eeprom must perform a write and read and then reenumerate , Somehow the firmware stalls and there is no attempt made to reenumerate. Is there a workaround for this considering that I have tried moving Temperature sensor method into the vendor command,
Hi CSK10 ,
can you please check once bus status while I2C is trying to write into EEPROM, that another device is not pulling down the line?
please check the status of bmRENUM bit while re-enumerate.
please share at what point it is going to stall.
Varun Narolkar
Hi CSK10 ,
Varun Narolkar
