I have a CYUSBS234 DVK but I can't find a way to read I2C data with it.
1. I have a PCB that sends data via I2C, and I would like to plug SCL and SDA to the DVK, then I can read the received data on my computer from the USB port of the DVK I know ffrom.this page how to hook up the i2c lines to the DVK, but I have no idea what software I could use to read the I2C data.
2. I also wanted to use capsense tuner with a custom capsense board, using CYUSBS234 DVK to interface with this custom board with an I2C line. I have my capsense PCB with a psoc 4100S embedded on it, which has an I2C pin connector, so I could hook it up to the CYUSBS234 DVK. Then, I would like to be able to use capsense tuner to read the capsense data from my custom PCB, using the CYUSBS234 DVK. Is this possible? If not, how could I proceed to read the I2C data from my custom board (using CYUSBS234 DVK, or any other method)?
Thank you very much!
To communicate with an external I2C device, you will have to write a custom application in platform like Visual Studios to get the data from the slave using the USB-Serial API library.
Please refer to the i2cmaster example which is present in the USB-Serial SDK (path: <installation directory>\Cypress\USB-Serial SDK\examples\usbserialexample)
you can download the USB-Serial SDK from this link: https://www.cypress.com/documentation/software-and-drivers/usb-serial-software-development-kit
Yatheesh
Yatheesh
