TRM: EZ-USB_TRM2.pdf
AN: AN613453.pdf (attached)
TRM section 15.5.3 says the EP2 empty flag is:
  1000 (binary) = 0x8 (hex)
AN613453's source code listing says
  PINFLAGSCD = 0xE0; // FLAGD - EP2 Emtpy flag
Which implies the EP2 empty flag is
  1110 (binary) = 0xE (hex)
Which is correct?
  EP2EF = 1000 = 0x8 [TRM]
  EP2EF = 1110 = 0xE [AN613453]
Thank you,
Chris
   PINFLAGSAB = 0x08; // FLAGA - EP2 Emtpy flag
  PINFLAGSCD = 0xE0; // FLAGD - EP6 FULL flag
 In the App note it seems the comments got swapped between the 2 lines. If you look at it, it should be FLAGA = EP2EF and FLAGD = EP6FF. Will get it fixed.
Anand
 Anand,
Thank you for your quick reply.  Can you please be a little more specific for me (I am new to this) and retype the two lines in their entirety as they should have appeared in the AN?  Presently they say:
  PINFLAGSAB = 0x08; // FLAGA - EP6 FULL flag
What should these two lines read after they are corrected?
 Thank you,
Chris
