I have 2 FX2 devices with different PIDs. Is it possible to open 2 of them for parallel control. If it so please advice how to do it
       Yes, It is. Please explain your requirement in detail so that we can help you more.
Hi PRJI, thanks for your help.
Here is the situation: I have 2 controller boards which use CY7C68013A for controlling communication with PC. They are the same VID but different PID, thus CyUSB can recognize them through their PID. I have no problem control each board one of a time, but if I try to control both of them in parallel by using 2 separate threads for each device, then runtime error issues happen. I lose the board control randomly (timeout). Seem to me that I just can take control on one board at a time.
On the app not of CyAPI, I find that if I open one device then it will call close() first if there is any open. This could be my problem since I try to open the handle for 2 devices in their thread. Thus if I open device 1 then will close then handle of device 2 if devece 2's opened --> lose the control of the device 2 control.
I really don't know how to work around on the issue. Is there any way to get a separate handle for each device?
        It can be done. Please create a tech support case at Support>Technical Support>Create my case: so that one of our Engineers can help you on this.
