Hello ,
I was looking for loading custom firmware from the driver files and here I came across the link Working of EZ Loader USB Firmware Loader - Infineon Developer Community .
Can i get the zip file for ez loader driver files , which contain ezloader.c ezloader.h files along with the application note ?
Hi CSK10 ,
Please follow Below KBA For Loading Flash :
ThankYou
Varun Narolkar
Hi CSK10 ,
please follow below steps mentioned in KBA:https://community.infineon.com/t5/Knowledge-Base-Articles/What-are-the-Basic-Steps-of-EZLOADER/ta-p/...
Thank you
Varun Narolkar
Hi Varun ,
I want to load custom firmware from the driver. For that i want to know how this can be done.
Can you provide me the link to the files which i can modify ?
Hi CSK10 ,
will look into this .zip file and update you ASAP.
Thank You
Varun Narolkar
Sure thanks.
Is there any other way to load the custom firmware using the driver ? if i am missing any
Hi CSK10,
Please use the control centre this app note is absolute ,you will get the source code for
C:\Program Files (x86)\Cypress\EZ-USB FX3 SDK\1.3\application\cpp\fwdownload_fx2
Thank You
Varun Narolkar
Hi CSK10 ,
ThankYou
Varun Narolkar
