09:44 AM
Dec 12, 2012
09:44 AM
Hi~
i have test firmware "Vend_Ax"
But i have not any debugger device.
Could you please let me know any firmware debugging ways?
(such as printf or assertion etc..)
10:14 AM
Dec 12, 2012
10:14 AM
If you are using FX2LP DVK then you can debug using serial port.
Please refer to the following application note.
http://www.cypress.com/?rID=39786
sai krishna.
12:44 AM
Dec 13, 2012
12:44 AM
You can also refer to the following application note: Setting Up, Using, and Troubleshooting the Keil(TM) Debugger Environment - AN42499
http://www.cypress.com/?rID=12960
You can do step by step debugging in this way.
