Is there a program that can configure the CY7C65215-32LTXI USB-Serial Dual CH Bridge by using text commands only on Windows without GUI?
@nami -san,
Thanks you for posting your question on this forum.
Could you elaborate what "using test commands" means? Also, let me know which OS you plan to use.
If you want to control the device through Command line, I think you can refer to the following thread and KBAs.
For CY7C65215, VID/PID configuration method for command line
Command line tool for configuring USB-Serial devices in Windows OS - KBA233326
CY7C65215-32LTXIT Linux Configuration Tool
@nami -san,
@nami -san,
Did the above answers resolve your issue?
Or do you have any additional questions?
If we do not receive any replies from you within two business days, we will assume that this inquiry has been resolved and let us close this thread.
