Translation_Bot
100 likes received
Actually it is the count parameter in this API for creating DMA channels, which is interpreted as the number of buffer zones to be allocated for the channel, can it be understood that which channel is configured, this parameter will allocate buffer zones for that channel?Weiqi__Zhong_0-1713258588150.png I can understand that which channel is configured, this parameter will allocate cache area for that channel?
smartconx_target@Q!w2e3r4t5y6u7i8o9p0||/t5/%E4%BD%8E%E9%80%9F-%E5%85%A8%E9%80%9F-%E9%AB%98%E9%80%9F-USB-%E5%A4%96%E8%AE%BE/%E5%86%85%E9%83%A8API%E5%8F%82%E6%95%B0%E7%96%91%E6%83%91/td-p/740308
Translation_Bot
100 likes received
Yes, count indicates the number of buffers in the DMA channel, as for which DMA channel to configure, it depends on which DMA channel create API you pass this DMA configuration to, such as using CyU3PDmaChannelCreate ( &glChHandleSlFifoUtoP ,
CY_U3P_DMA_TYPE_MANUAL, &dmaCfg); create U to P channel, then the count parameter in dmaCfg is used to create this channel;
In addition, about the FX3 API, etc. you can refer to the FX3API.pdf file
smartconx_target@Q!w2e3r4t5y6u7i8o9p0||/t5/%E4%BD%8E%E9%80%9F-%E5%85%A8%E9%80%9F-%E9%AB%98%E9%80%9F-USB-%E5%A4%96%E8%AE%BE/%E5%86%85%E9%83%A8API%E5%8F%82%E6%95%B0%E7%96%91%E6%83%91/m-p/740841
Translation_Bot
100 likes received
