Hello ,
I want to make use of the interrupt ISR_Ures(void) interrupt 0.
In the TRM it is mentioned that USB host signals a bus reset
How is that done ?
- fx2lp
Hi CSK10,
please follow Renumeration in firmware for FX1/FX2LP - Infineon Developer Community
when you are using mentioned command will re-enumurate device and the host will reset the device.
Thank You
Varun Narolkar
Hi CSK10,
please follow the TRM document for sending USB BUS Reset please check TRM Document chapter 7.5.
for handling interrupt please follow chapter 4.
please let me know that exactly what you want to implement.
Thank you
Varun Narolkar
i want to implement a eepromread inside the ISR_Ures(void) interrupt 0.
For that i want to know how could a reset be signalled from the host side.
I know about the reset but i dont want the firmware that is flashed to be lost
Hi CSK10 ,
can you please let us know which is your host system windows or Linux?
Thank you
Varun Narolkar
Its windows
Hi CSK10,
Thank You
Varun Narolkar
