10:34 AM
Jan 06, 2015
10:34 AM
EP2 is OUT EP.
With EP2 FIFO, I want to run GPIF BURST WRITE.
But, I want to use the data from EP2FIFO[10] not from the first address.
Is it possible to do that ?
10:37 AM
Jan 06, 2015
10:37 AM
Please let me know which product you are using?
Vikas.
07:47 PM
Jan 07, 2015
07:47 PM
I'm using FX2LP.
Thanks...
09:37 PM
Jan 07, 2015
09:37 PM
If you want to start from Ep2fifo[10] there is no direct way. In case if you have any slave select / write enable pin which is controlled by some CTL pins of FX2LP. Then don't assert the pin for first 10 write. After 10 cycles assert the pin. This would flush out the first 10 bytes.
Vikas.
