I'm about to implement a software (C# Windows Application) to communicate with my I2C Hardware via a CY7C68013a.
I started using the CYUSB.dll and was able to find the USB Device. Unfortunately I'm stocked now.
How can I implement a I2C transaction between my software and the hardware?
Do you have a example for this?
Thanks a lot
Best regards from germany
Bernhard Waechter
Tne I2C Transfer can be done using Vendor requests. Refer to the Control Center C# source code for how to implement vendor requests. Your FX2LP Firmware should be able to handle vendor requests and perform I2C Transfers,
-Madhu Sudhan
Hello Madhu,
thanks for your fast reply. I already got it working with using Vendor Requests.
We can close this ticket.
Thanks a lot
Regards Bernhard
Good day, if possible can I see your I2C code or example of your I2C code (i.e. how to implement vendor requests to perform I2C)?
Greatly appreciated
Fawwaz Hosein
