We are validating RTS/CTS flow control of UART vendor mode on CYUSB236 EVK by sending a 7MB text file from SCB0 to SCB1. With referring to Cypress USB API document, we develop a program via Cypress Linux library to send, receive data, enable RTS/CTS flow control and register CTS notification callback function.
With RTS/CTS flow control enabled on both UART ports, the receiver(SCB1) showed some packets loss as transmitter(SCB0) just continuously sent data without knowing how to check CTS status.
We can’t find any Cypress document or sample codes of handling CTS via Cypress library on CYUSB236 or CY7C65215 website.
Could you provide document or sample codes of implementing RTS/CTS flow control correctly via Cypress library to prevent packets loss on receiver ?
Justy Huang
Hi Justy,
Apologies for the delay in response. I tested the source code provided by you and the total received bytes are always identical to the sent bytes.
Can you please confirm if you start receiving the data before sending data?
Meghavi
Hi Justy,
Can you please provide the following details:
1) Which driver you are using?
2) Please let us know the configuration like baud rate, bits, flow control, etc.
Meghavi
Hi Meghavi,
1) Attached 'CyUSBSerial_SDK_Linux.zip' is the library we have used for implementing UART vendor mode flow control on CYUSB236 EVK. File 'CyUSBSerail_SDK_Linux\linux\testUtility\Test_Utility.c' in that attached contains all the codes we implemented for enabling RTS/CTS flow control, data Tx/Rx ...etc.
2) Attached PPT contains detailed setup for UART vendor mode flow control validation on CYUSB236 and UART config of two ports on CYUSB236 are:
Baud rate:1Mbps, Data width:8 bits, Stop bit:1, Parity:None
Justy Huang
Hi Justy,
Can you please confirm if you have referred the cyuart.c which is present in USB_Serial SDK: USB-Serial SDK\linux_driver\CyUSBSerial_SDK_Linux.zip\CyUSBSerial_SDK_Linux\CyUSBSerial_SDK_Linux\linux\library ?
Meghavi
Hi Meghavi,
Yes, I referred the APIs in cyuart.c to implement recv and send functions for Cypress UART vendor mode. You can check the source code in attached CyUSBSerial_SDK_Linux.zip\linux\testUtility\Test_Utility.c I implemented for validating HW flow control of Cypress UART vendor mode.
Justy Huang
Hi Justy,
Meghavi
