How to get CyUSB3 driver source code for 1.2.3.14 ?
I  have 1.2.3.10 only.
This has the latest:
http://www.cypress.com/file/289981/download
- Madhu Sudhan
Hi ,Thank you for your help.
I have question for INF file which is generated by build_script.
I checked generated INF file by "chkinf" tool, so 2 warnings are found in "Coinstaller" section as attached.
My questions are:
1) How to remove these warnings ?
2) Why needs "Coinstaller" ?
3) What is happen if does not use "Coinstaller" ?
;-------------- WDF Coinstaller installation
[SourceDisksFiles]
; (W22.1.2400) SOURCEDISKSFILES is defined more than once. This will result in the sections being collapsed into a single section which may be unexpected. WdfCoInstaller01011.dll=1 ; make sure the number matches with SourceDisksNames
[DestinationDirs]
; (W22.1.2400) DESTINATIONDIRS is defined more than once. This will result in the sections being collapsed into a single section which may be unexpected. CoInstaller_CopyFiles = 11
Best regards.
