Hello
after flashing my hardware, a Bitstream X3 Controller for midi the system is totaly dead.
The first PCB mounts a Cypress AN2131 wich then is used to programm the Zylog Z8 over Midi.
I have a .hex firmware file from the brand who made the Bitstream X3, wich i have burned on a 24L64A eeprom
but the Cypress Chip is not loading the firmare .
Device Manager says unknown Device USB\VID_0547&PID_2131\5&39cd783b&0&1
Now i wonder if this .hex file must be converted to a .bix file before burning it into the eeprom
or is there any other solution to send the .hex to the Cypress
Zip with .hex is attached
sorry for my bad english
kindly Maurizio
Hi Maurizio,
please download fx3 SDK from given FX3-sdk .
you will get the drivers from the below path C:\Program Files (x86)\Cypress\EZ-USB FX3 SDK\1.3
Thank you
Varun Narolkar
Hi Maurizio,
Thank you
Varun Narolkar
i have tried the drivers but it is still not recognized as an Audio Interface, burned the eeprom with any kind of
solution IIc file .bix file .hex anbd .bin also the file giving me from jerome the inventor of the Bitstream does not work.
So i have a basic question if the Cypress AN2131SC is broken i assume there is no request from windows to install any driver.
also i am able to install the pcb as Cypress Antioch UBS Boot device ( just to see if any driver works) and it is installed.
So why is the AN2131 not loading the firmware from the eeprom into the flash memory ?
could it be the Quartz ?
how can i test or force an upload to the chip itself from outside over UBS cable
thx
Hi Maurix ,
can you please let us know in which mode you want to enumerate CDC or VENDOR.
in case if you want to use this device in CDC Mode please use Microsoft drivers.
Thank You
Varun Narolkar
