How to change the configuration of CY7C65215-32LTXI
kyohei
I'm using CY7C65215-32LTXI in our design.
I have changed the configuration like following by using USB-Serial Configuration Utility.
Before:
SCB0
Mode:I2C
Protocol:Vendor
SCB1
Mode:SPI
Protocol:Vendor
After:
SCB0
Mode:UART
Protocol:CDC
SCB1
Mode:UART
Protocol:CDC
After this change, there have been no device detected by usb-serial configurariton utility. And also device manager could not detect com port.
Please tell me the way to back the configuration under this circumstance.
MallikaK_22
50 likes received 750 replies posted 250 solutions authored
Could you please let me know if you have disabled the vendor manufacturing interface as well?
Could you also let me know if you are using Cypress DVK or a custom board?
kyohei
Before and after the change, "Enable manufactuaring interface" is checked.
And I'm using custom borad.
MallikaK_22
Kindly share the schematics  of your board.
