09:40 PM
May 22, 2013
09:40 PM
Hi I'm looking at ezusbsys.c of ezusbdrv. I can see that maximumtransfersize. It's 64*1024 Why ezusb driver's maximumtransfersize is 64*1024? if i much more set like 256*1024, is this affect to usb slave fifo's bulk read speed up ?
12:15 AM
May 27, 2013
12:15 AM
Hi, You can increase that parameter if your operating system supports. You can refer to the web page given below for knowing the max transfer size defined for a particular operating system. http://msdn.microsoft.com/en-us/library/ff538112.aspx Thanks, sai krishna.
